The GPOE-USB lets you power USB-C and 5 V DC devices directly from PoE. No nearby power outlet required! It converts standard PoE input into stable 5 V power while maintaining 2.5 Gigabit Ethernet passthrough connectivity.
Perfect for installations where power access is inconvenient or impossible: wall-mounted tablets, Raspberry Pi projects, sensors, controllers, air quality monitors, and MikroTik devices with USB-C power input but without PoE Input support.
With ~15 W output power, the GPOE-USB can handle significantly heavier loads than typical mass market PoE-to-USB adapters. The integrated DC terminal output also expands compatibility with low-voltage 2-pin terminal 5 V DC devices beyond USB-C.
One Ethernet cable for both data and power means cleaner installations, fewer adapters, and easier deployment almost anywhere.
