Skip to main content
Discontinued
wAP ac BE
Small dual-band 2.4 / 5GHz black weatherproof wireless access point for mounting on a ceiling, wall or pole
IP 54
Outdoors
PoE
Dual-band
wAP ac BE
Product image
Product image
Product image thumbnail
The wAP ac is a small weatherproof wireless access point for your mobile devices, perfect for installation outside your house, in the garden, on your porch or anywhere else where you need wireless access from your phone or computer.
The device has one Gigabit Ethernet port, it supports 802.11a/b/g/n/ac wireless protocols and can work at both the 2.4GHz and 5GHz frequencies simultaneously. It looks unobtrusive and sleek.
The wAP ac is weatherproof and can be fixed to any external wall from the inside of the case - so that it is securely attached to it’s mounting location.
We have two versions available.
- RBwAPG-5HacT2HnD-BE (International) supports 2412-2484MHz and 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
- RBwAPG-5HacT2HnD-BE-US (USA) is factory locked for 2412-2462MHz, 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
Specification
Specifications
  • Product code RBwAPG-5HacT2HnD-BE
  • Suggested price $89.00
  • Architecture MIPSBE
  • CPU QCA9556
  • CPU core count 1
  • CPU nominal frequency 720 MHz
  • Dimensions 185 x 85 x 30 mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
Wireless capabilities
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 2
  • Wireless 2.4 GHz chip model QCA9556
  • Wireless 2.4 GHz generation Wi-Fi 4
  • Wireless 5 GHz Max data rate 1300 Mbit/s
  • Wireless 5 GHz Number of chains 3
  • Wireless 5 GHz standards 802.11a/n/ac
  • Antenna gain dBi for 5 GHz 2
  • Wireless 5 GHz chip model QCA9880
  • Wireless 5 GHz generation Wi-Fi 5
  • WiFi speed AC1600
Ethernet
  • 10/100/1000 Ethernet ports 1
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 12 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 11-57 V
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP IP54
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for mipsbe devices.
System Package
More in download page
