Skip to main content
Discontinued
SXT G-5HnD
Gigabit SXT Dual pol antenna Integrated design
Outdoors
PoE
SXT G-5HnD
Product image
Product image thumbnail
SXTG-5HnD is a low cost, high speed 5GHz outdoor sector AP, with a Gigabit port, to fully utilize the capacity of 802.11n. At 25° degree beamwidth, you can conveniently create sector setups with a few client devices because this device comes with an AP license (Level4).
Complete with a ready to mount enclosure and built-in 16dBi antenna, the package contains everything you need to make AP, point to point link or CPE.
Package contains SXTG-5HnD, mounting loops, PoE injector, power adapter
SXT install guide:
Video thumbnail
Specification
Specifications
  • Product code RBSXTG-5HnD
  • Suggested price $99.00
  • Architecture MIPSBE
  • CPU AR7242
  • CPU core count 1
  • CPU nominal frequency 400 MHz
  • Dimensions 140x140x56mm, 265g
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 32 MB
  • Storage size 64 MB
  • Storage type NAND
  • Tested ambient temperature -30C to +70C
Powering
  • Max power consumption without attachments 7W
  • PoE in Passive PoE
Wireless specifications
  • Wireless 5 GHz Max data rate 300 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n
  • Antenna gain dBi for 5 GHz 16
  • Wireless 5 GHz chip model AR9280
  • Wireless 5 GHz generation Wi-Fi 4
Ethernet
  • 10/100/1000 Ethernet ports 1
Peripherals
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for mipsbe devices.
System Package
More in download page
