Skip to main content
Discontinued
QRT 2
2.4Ghz AP/Backbone/CPE, dual-chain, Gigabit Ethernet
Outdoors
PoE
QRT 2
Product image
Product image
Product image
Product image thumbnail
The QRT-2 is rugged outdoor flat panel antenna, with a built in RouterBOARD. The device has a 17dBi antenna and a super high power 2Ghz wireless transmitter.
Inside is a new dual chain wireless device, with high performance, high output power wireless transmitter, and a Gigabit Ethernet port, to fully utilize the benefit of 802.11n high speed wireless.
Easy to use and quick to deploy, QRT is ideal for point-to-point links.
Specification
Specifications
  • Product code RBQRTG-2SHPnD
  • Suggested price $149.00
  • Architecture MIPSBE
  • CPU AR9342
  • CPU core count 1
  • CPU nominal frequency 600 MHz
  • Dimensions 309x230x50mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 11 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 13-30 V
Wireless specifications
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 17
  • Wireless 2.4 GHz chip model AR9342
  • Wireless 2.4 GHz generation Wi-Fi 4
Ethernet
  • 10/100/1000 Ethernet ports 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
System Package
More in download page
Related Products
