Skip to main content
Discontinued
RB951G-2HnD
2.4Ghz AP, 5xGigabit Ethernet, USB, 600MHz CPU, 128MB RAM
PoE
RB951G-2HnD
Product image
Product image thumbnail
The RB951G-2HnD is a wireless SOHO Gigabit AP with a new generation Atheros CPU and more processing power. It has five Gigabit Ethernet ports, one USB 2.0 port and a high power 2.4GHz 802.11b/g/n wireless AP with antennas built in.
In comparison with previous model RB751G-2HnD, it has more powerful 600Mhz CPU (instead of 400Mhz), more RAM - 128MB instead of 64MB, same form factor and price. The device is very small and will look good in any home or office, wall mounting anchor holes are provided.
Package contains RouterBOARD 951G-2HnD in a plastic case and power adapter.
Specification
Specifications
  • Product code RB951G-2HnD
  • Suggested price $89.95
  • Architecture MIPSBE
  • CPU AR9344
  • CPU core count 1
  • CPU nominal frequency 600 MHz
  • Switch chip model AR8327-BL1A
  • Dimensions 113x138x29mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 128 MB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -20C .. +50C
Wireless capabilities
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 2.5
  • Wireless 2.4 GHz chip model AR9344
  • Wireless 2.4 GHz generation Wi-Fi 4
Ethernet
  • 10/100/1000 Ethernet ports 5
Peripherals
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 8-30 V
  • Max power consumption 7 W
  • PoE in Passive PoE
  • PoE in input Voltage 8-30 V
Certification & Approvals
  • Certification FCC
  • IP IP20
Other
  • Beeper Yes
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for mipsbe devices.
More in download page
