Skip to main content
Discontinued
hAP mini
Tiny size home 2.4Ghz AP with three LAN ports
hAP mini
Product image
Product image
Product image thumbnail
The hAP mini is a small 2GHz wireless access point for home or small offices. It has three ports, which are configured as one Internet port and two LAN ports, but can be reconfigured as desired, using the powerful RouterOS configuration options.
The powerful 650MHz CPU gives you full access to the wide variety of features provided by the versatile RouterOS operating system, but if all you want is a simple access point - it is already configured out of the box. You simply need to open it’s web configuration page and provide a password for it.
Specification
Specifications
  • Product code RB931-2nD
  • Suggested price $22.95
  • Architecture SMIPS
  • CPU QCA9533
  • CPU core count 1
  • CPU nominal frequency 650 MHz
  • Switch chip model QCA9533-BL3A
  • Dimensions 48 x 78 x 81mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 32 MB
  • Storage size 16 MB
  • Storage type FLASH
  • Tested ambient temperature -20°C to 70°C
Wireless capabilities
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 1.5
  • Wireless 2.4 GHz chip model QCA9533
  • Wireless 2.4 GHz generation Wi-Fi 4
Ethernet
  • 10/100 Ethernet ports 3
Powering
  • MicroUSB input Voltage 5 V
  • Number of DC inputs 1 (MicroUSB)
  • Max power consumption 3.5 W
  • Cooling type Passive
Certification & Approvals
  • Certification FCC, IC
  • IP IP20
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for smips devices.
System Package
More in download page
