Skip to main content
Discontinued
RB751U-2HnD
2.4Ghz 1000mW AP, 5xEthernet, USB, 400MHz CPU, 32MB RAM,
PoE
RB751U-2HnD
Product image
Product image
Product image
Product image
Product image thumbnail
The RB751U-2HnD is the wireless SOHO AP you have been waiting for!
It has five Ethernet ports, one USB 2.0 port and a high power 2.4Ghz 1000mW 802.11b/g/n wireless AP with antennas built in. It’s also possible to connect an external MMCX antenna to replace one of the built in antennas.
The device is very small and will look good in any home or office, wall mounting anchor holes are provided.
Package contains RB751U-2HnD in a plastic case and power adapter.
Specification
Specifications
  • Product code RB751U-2HnD
  • Suggested price $59.95
  • Architecture MIPSBE
  • CPU AR7241
  • CPU core count 1
  • CPU nominal frequency 400 MHz
  • Dimensions 113x138x29mm
  • RouterOS license 4
  • Operating System RouterOS
  • Storage size 64 MB
  • Storage type NAND
  • Tested ambient temperature -20C .. +50C
Wireless capabilities
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 2.5
  • Wireless 2.4 GHz chip model AR9283
  • Wireless 2.4 GHz generation Wi-Fi 4
Ethernet
  • 10/100 Ethernet ports 5
Peripherals
  • Number of USB ports 1
Powering
  • Number of DC inputs 1
  • PoE in Passive PoE
Included parts
Note
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for mipsbe devices.
More in download page
