Skip to main content
Discontinued
RB711-2Hn
400Mhz CPU, 32MB RAM, 1xEthernet, onboard 2.4Ghz wireless, RouterOS L3
Outdoors
PoE
RB711-2Hn
Product image
Product image thumbnail
The RB711 is a small CPE type RouterBOARD wireless router with an integrated 2GHz 802.11b/g/n wireless card.
RB711 includes RouterOS - the operating system, which can be a router, firewall, bandwidth manager, a CPE and more - all at the same time.
This device has one MMCX connector, allowing single chain connectivity. The integrated wireless card is capable of up to 27dBm transmit power output.
Built in 16kV ESD protection on RF port.
Supported frequency:
2Ghz band: 2192-2539Mhz
Specification
Specifications
  • Product code RB711-2Hn
  • Suggested price $45.00
  • CPU nominal frequency 400 MHz
  • Dimensions 105x105mm
  • RouterOS license 3
  • Storage size 64 MB
  • Storage type NAND
  • Tested ambient temperature -30 .. +65C
Powering
  • PoE in Passive PoE
Ethernet
  • 10/100 Ethernet ports 1
Documents
Brochure
.PDF
Brochure PDF first page
