Skip to main content
Discontinued
RB2011iL-IN
Desktop metal case, 5xEthernet, 5xGigabit Ethernet, PoE out on port 10, 600MHz CPU, 64MB RAM, RouterOS L4
PoE
RB2011iL-IN
Product image
Product image thumbnail
The RB2011 is a low cost multi port device series. Designed for indoor use, and available in many different cases, with a multitude of options.
The RB2011iL-IN is the most basic model, with five Gigabit ethernet ports, five Fast ethernet ports, power jack and PoE support.
It’s powered by the new Atheros next generation 600MHz 74K MIPS network processor and has 64MB of RAM and a Level4 RouterOS license.
There is PoE output function for port #10 - it can power other PoE capable devices with the same voltage as applied to the unit. Maximum load on the port is 500mA.
RouterBOARD 2011iL-IN comes with desktop enclosure and power supply.
Wall mount kit for network closet is available for purchase as an optional accessory.
Specification
Specifications
  • Product code RB2011iL-IN
  • Suggested price $99.00
  • Architecture MIPSBE
  • CPU AR9344
  • CPU core count 1
  • CPU nominal frequency 600 MHz
  • Switch chip model AR8327-BL1A-R
  • Dimensions 230x90x25mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -35C to +65C
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 8-30 V
  • Max power consumption 18 W
  • Max power consumption without attachments 6 W
  • PoE in Passive PoE
  • PoE in input Voltage 8-30 V
PoE-out
  • PoE-out ports Ether10
  • PoE out Passive PoE
  • Low voltage PoE-Out current limit 500 mA
  • Max total out (A) 500 mA
Ethernet
  • 10/100 Ethernet ports 5
  • 10/100/1000 Ethernet ports 5
Other
  • Beeper Yes
Included parts
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for mipsbe devices.
System Package
More in download page
Related Products
