Skip to main content
Discontinued
RB2011UiAS-2HnD
600MHz CPU, 128MB RAM, 5xEthernet, 5xGigabit Ethernet, SFP cage, 1000mW 2.4Ghz onboard, USB, RouterOS L5
Outdoors
PoE
SFP/SFP+
RB2011UiAS-2HnD
Product image
Product image thumbnail
The RB2011 is a low cost multi port device series, powered by RouterOS, a fully featured routing operating system which has been continuously improved for fifteen years. Dynamic routing, hotspot, firewall, MPLS, VPN, advanced quality of service, load balancing and bonding, real-time configuration and monitoring - just a few of the vast number of features supported by RouterOS.
RouterBOARD 2011UiAS-2HnD has most features and interfaces from all our Wireless routers. It’s powered by the new Atheros 600MHz 74K MIPS network processor, has 128MB RAM, five Gigabit LAN ports, five Fast Ethernet LAN ports and SFP cage (SFP module not included!). Also, it features powerful 1000mW dual chain 2.4Ghz 802.11bgn wireless onboard, RJ45 serial port, microUSB port and RouterOS L5 license.
There are two MMCX connectors for adding external antennas, so you can create powerful dual chain wireless backbone, AP or CPE unit.
There is PoE output function for port #10 - it can power other PoE capable devices with the same voltage as applied to the unit. Maximum load on the port is 500mA.
Tested and recommended to use with MikroTik SFP modules: S-85DLC05D, S-31DLC20D and S-35/53LC20D (not included)
Specification
Specifications
  • Product code RB2011UiAS-2HnD
  • Suggested price $99.00
  • Architecture MIPSBE
  • CPU AR9344
  • CPU core count 1
  • CPU nominal frequency 600 MHz
  • Switch chip model AR8327-BL1A-R
  • Dimensions 214mm x 86mm
  • RouterOS license 5
  • Operating System RouterOS
  • Size of RAM 128 MB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -40°C to 60°C
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 8-30 V
  • Max power consumption 6 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 8-30 V
PoE-out
  • PoE-out ports Ether10
  • PoE out Passive PoE
  • Low voltage PoE-Out current limit 510 mA
  • Max total out (A) 510 mA
Wireless specifications
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Wireless 2.4 GHz chip model AR9344
  • Wireless 2.4 GHz generation Wi-Fi 4
Ethernet
  • 10/100 Ethernet ports 5
  • 10/100/1000 Ethernet ports 5
Fiber
  • SFP ports 1
Peripherals
  • Serial console port RJ45
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification FCC
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for mipsbe devices.
More in download page
