Skip to main content
Discontinued
RB1100AHx2-LM
1U rackmount, 13x Gigabit Ethernet, 1066MHz Dual Core CPU, 512MB RAM, RouterOS L6
PoE
RB1100AHx2-LM
Product image
Product image thumbnail
RB1100AHx2-LM is 1U rackmount Gigabit Ethernet router - with a dual core CPU, it can reach up to a million packets per second and supports hardware encryption!
It has thirteen individual gigabit Ethernet ports, two 5-port switch groups, and includes Ethernet bypass capability. 512MB of SODIMM RAM are included, there is one microSD card slot, a beeper and a serial port.
The RB1100AHx2-LM comes preinstalled in a 1U aluminium rackmount case, power supply and power plug, assembled and ready to deploy.
Specification
Specifications
  • Product code RB1100AHx2-LM
  • Suggested price $339.00
  • Architecture PPC
  • CPU P202ASSE2KFB
  • CPU core count 2
  • CPU nominal frequency 1 GHz
  • Switch chip model AR8327-BL1A-R
  • Dimensions 1U case: 44 x 176 x 442 mm, 1200g. Board only: 365g
  • RouterOS license 6
  • Operating System RouterOS
  • Size of RAM 512 MB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -30C to +60C
Powering
  • Number of DC inputs 1
  • PoE in Passive PoE
Ethernet
  • 10/100/1000 Ethernet ports 13
Peripherals
  • Memory card type microSD
  • Memory Cards 1
  • Serial console port RS232
Other
  • CPU temperature monitor Yes
  • Current Monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Note
Ethernet test results
Documents
Download
Latest RouterOS stable release v7.25.2 download files for ppc devices.
System Package
More in download page
