MikroTik introduces the R52H wireless 802.11a+b+g miniPCI card for multiband high speed
applications. It works on 2.192-2.539 and 4.920-6.100GHz
frequency range (Specific frequency range can be limited by country regulations) and supports Turbo mode for faster transfers. The card performs best
when coupled with the MikroTik RouterOS.
R52H is optimized to work with MikroTik Nstreme protocol to reach extra long distances at a
great speed. The Nstreme protocol is MikroTik proprietary wireless protocol created to
overcome speed and distance limitations of IEEE 802.11 standards and to extend
point-to-point and point-to-multi point wireless link performance. The new Nstreme-dual
protocol designed to provide real full-duplex communications over wireless with a pair of
wireless cards – one for transmitting data and one for receiving.
Card has two U.fl connectors for external antennas
| Details | |
| Product code | R52-350 |
| 2GHz | Yes |
| 5GHz | Yes |
| 802.11 Turbo mode support | Yes |
| Chipset | AR5414 |
| Connector | uFl |
| Format | miniPCI |
| MTBF | Approximately 100'000 hours at 25C |
| Output power | 25dBm |
| Tested ambient temperature | -40℃ to +70℃ |
| Suggested price | $59.00 |
Download: Full CE declaration (PDF)
Information about R52H
| [BG] Bulgarian | С настоящето, "Mikrotikls SIA", декларира, че R52H е в съответствие със съществените изисквания и другитеприложими разпоредби на Директива 2014/53/EC. |
| [CZ] Czech | "Mikrotikls SIA" tímto prohlašuje, že R52H splňuje základní požadavky a všechna příslušná ustanoveni Směrnice 2014/53/ES. |
| [DK] Danish | Undertegnede "Mikrotikls SIA" erklærer herved, at følgende udstyr R52H overholder de væsentlige krav og øvrige relevante krav i direktiv 2014/53/EF. |
| [DE] German | Hiermit erklärt "Mikrotikls SIA", dass sich das Gerät R52H in Übereinstimmung mit den grundlegenden Anforderungen und den übrigen einschlägigen Bestimmungen der Richtlinie 2014/53/EG befindet. |
| [EE] Estonian | Käesolevaga kinnitab "Mikrotikls SIA" seadme R52H vastavust direktiivi 2014/53/EÜ põhinõuetele ja nimetatud direktiivist tulenevatele teistele asjakohastele sätetele. |
| [GR] Greek | ΜΕ ΤΗΝ ΠΑΡΟΥΣΑ Ο ΚΑΤΑΣΚΕΥΑΣΤΗΣ "Mikrotikls SIA" ΔΗΛΩΝΕΙ ΟΤΙ R52H ΣΥΜΜΟΡΦΩΝΕΤΑΙ ΠΡΟΣ ΤΙΣ ΟΥΣΙΩΔΕΙΣ ΑΠΑΙΤΗΣΕΙΣ ΚΑΙ ΤΙΣ ΛΟΙΠΕΣ ΣΧΕΤΙΚΕΣ ΔΙΑΤΑΞΕΙΣ ΤΗΣ ΟΔΗΓΙΑΣ 2014/53/ΕΚ |
| [EN] English | Hereby, "Mikrotikls SIA", declares that this R52H is in compliance with the essential requirements and other relevant provisions of Directive 2014/53/EC. |
| [ES] Spanish | Por la presente, "Mikrotikls SIA", declara que este R52H cumple con los requisitos esenciales y otras exigencias relevantes de la Directiva 2014/53/EC. |
| [IT] Italian | Con la presente "Mikrotikls SIA" dichiara che questo R52H è conforme ai requisiti essenziali ed alle altre disposizioni pertinenti stabilite dalla direttiva 2014/53/CE. |
| [LV] Latvian | Ar šo "Mikrotikls SIA" deklarē, ka R52H atbilst Direktīvas 2014/53/EK būtiskajām prasībām un citiem ar to saistītajiem noteikumiem. |
| [LT] Lithuanian | Šiuo "Mikrotikls SIA" deklaruoja, kad šis R52H atitinka esminius reikalavimus ir kitas 2014/53/EB Direktyvos nuostatas |
| [HU] Hungarian | A "Mikrotikls SIA" ezzennel kijelenti, hogy a R52H típusú beren-dezés teljesíti az alapvető követelményeket és más 2014/53/EK irányelvben meghatározott vonatkozó rendelkezéseket. |
| [NL] Dutch | Hierbij verklaart "Mikrotikls SIA" dat het toestel l R52H in overeenstemming is met de essentiële eisen en de andere relevante bepalin-gen van richtlijn 2014/53/EG. |
| [PL] Polish | Niniejszym "Mikrotikls SIA" deklaruje że R52H jest zgodny z zasadniczymi wymaganiami i innymi właściwymi postanowieniami Dyrektywy 2014/53/EC. |
| [PT] Portuguese | Eu, "Mikrotikls SIA", declaro que o R52H cumpre os requisitos essenciais e outras provisões relevantes da Directiva 2014/53/EC. |
| [RO] Romanian | Prin prezenta, "Mikrotikls SIA", declară că aparatul R52H este în conformitate cu cerinţele esenţiale şi cu alte prevederi pertinente ale Directivei 2014/53/CE.. |
| [SK] Slovak | "Mikrotikls SIA" týmto vyhlasuje, že R52H spĺňa základné požiadavky a všetky príslušné ustanovenia Smernice 2014/53/ES. |
| [SI] Slovenian | "Mikrotikls SIA" izjavlja, da je ta R52H v skladu z bistvenimi zahtevami in drugimi relevantnimi določili direktive 2014/53/ES. |
| [FI] Finish | "Mikrotikls SIA" vakuuttaa täten että R52H tyyppinen laite on direktiivin 2014/53/EY oleellisten vaatimusten ja sitä koskevien direktiivin muiden ehtojen mukainen. |
| [SE] Swedish | Denna utrustning är i överensstämmelse med de väsentliga kraven och andra relevanta bestämmelser i direktiv 2014/53/EC. |
| [NO] Norwegian | "Mikrotikls SIA", Erklærer herved at R52H er i samsvar med de grunnleggende krav og øvrige relevante krav i direktiv 2014/53/EF. |
