Skip to main content
Discontinued
CCR1016-12G-BU
16 cores x 1.2Ghz CPU, 2GB RAM, 12xGigabit Ethernet, LCD and power supply, RouterOS L6
Outdoors
PoE
CCR1016-12G-BU
Product image
Product image thumbnail
CCR1016 is an industrial grade super fast router with cutting edge 16 core CPU. If you need many millions of packets per second - Cloud Core Router is your best choice.
The device has twelve Gigabit ethernet ports, a serial console cable and a USB port. The CCR1016-12G has two SODIMM slots, by default it is shipped with 2GB of RAM, but has no memory limit in RouterOS (will accept and utilize 16GB or more).
Package contains CCR1016-12G-BU, power supply and LCD display. It is shipped without enclosure for OEM installations.
Specification
Specifications
  • Product code CCR1016-12G-BU
  • Suggested price $625.00
  • Architecture TILE
  • CPU TLR4-01680CG-10C
  • CPU core count 16
  • CPU nominal frequency 1.2 GHz
  • Dimensions 355x145x55cm
  • RouterOS license 6
  • Operating System RouterOS v6 (64bit)
  • Size of RAM 2 GB
  • Storage size 512 MB
  • Storage type NAND
  • Tested ambient temperature Max ambient temperature 50C @1.2Ghz; 70C @1Ghz CPU core frequency
Powering
  • Number of DC inputs 2
  • PoE in Passive PoE
Ethernet
  • 10/100/1000 Ethernet ports 12
Peripherals
  • Serial console port RS232
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type microUSB type AB
Other
  • CPU temperature monitor Yes
  • Current Monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Note
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for tile devices.
More in download page
