Skip to main content
Discontinued
CCR1016-12G
1U rackmount, 12x Gigabit Ethernet, LCD, 16 cores x 1.2GHz CPU, 2GB RAM, 17.8mpps fastpath, Up to 12Gbit/s throughput, RouterOS L6, Dual PSU
CCR1016-12G
Product image
Product image
Product image thumbnail
CCR1016-12G is an industrial grade router with a cutting edge 16 core CPU. If you need many millions of packets per second - Cloud Core Router is your best choice. Unit is equipped with 12 x Gigabit Ethernet ports and color touchscreen LCD.
The new r2 version has onboard 2GB of RAM, full size USB slot and dual PSU for redundancy!
Specification
Specifications
  • Product code CCR1016-12G
  • Suggested price $705.00
  • Architecture TILE
  • CPU TLR4-01680
  • CPU core count 16
  • CPU nominal frequency 1.2 GHz
  • CPU Threads count 16
  • Dimensions 443 x 193 x 44 mm
  • RouterOS license 6
  • Operating System RouterOS
  • Size of RAM 2 GB
  • Storage size 512 MB
  • Storage type NAND
  • Tested ambient temperature -20°C to 60°C
Powering
  • Number of AC inputs 2
  • AC input range 100-240
  • Max power consumption 42 W
  • Max power consumption without attachments 37 W
  • Cooling type 2 fans
Ethernet
  • 10/100/1000 Ethernet ports 12
Peripherals
  • Serial console port RJ45
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • CPU temperature monitor Yes
  • PCB temperature monitor Yes
  • Mode button Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP20
Included parts
Note
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for tile devices.
More in download page
