Skip to main content
BaseBox 5
5Ghz integrated AP/Backbone/CPE, 2xRP-SMA Female connectors, miniPCI-e slot, Gigabit Ethernet
Mini PCI-e
Outdoors
PoE
BaseBox 5
Product image
Product image
Product image
Product image thumbnail
The RB912 in an outdoor enclosure, fit with two RP-SMA Female connectors for antennas, and a cable hood for protection against moisture. Also available are three additional places for antenna connectors, in case you wish to use the RB912 miniPCIe slot for one more wireless interface to make a dual band device.
The case can be opened with one hand, and is protected against the elements. USB, Ethernet and a Grounding wire exits are provided on the bottom, behind a protective door.
Comes with a mounting loop for tower/pole mounting, and a separate DIN rail mount is also provided. Package also includes a PoE injector
and power supply unit.
Box contains: RB912 outdoor unit, PSU, PoE injector, mounting loop, DIN rail mount
- RB912UAG-5HPnD-OUT-US (USA) is factory locked for 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
- RB912UAG-5HPnD-OUT (International) supports 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
Specification
Specifications
  • Product code RB912UAG-5HPnD-OUT
  • Suggested price $89.00
  • Architecture MIPSBE
  • CPU AR9342
  • CPU core count 1
  • CPU nominal frequency 600 MHz
  • Dimensions 246x135x50mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 128 MB
  • Storage type NAND
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 12 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 8-30 V
Wireless specifications
  • Wireless 5 GHz Max data rate 300 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n
  • Wireless 5 GHz chip model AR9342
  • Wireless 5 GHz generation Wi-Fi 4
Ethernet
  • 10/100/1000 Ethernet ports 1
Peripherals
  • Number of SIM slots 1 Modem (Mini SIM)
  • MiniPCI-e slots 1
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.20.6 download files for mipsbe devices.
More in download page
