Skip to main content
Discontinued
Cube 60G ac
A high-speed 60 GHz CPE with Gigabit Ethernet and a 5 GHz failover. The easy and affordable way of eliminating interference and downtime!
ARM
Quad-core CPU
IP 54
Outdoors
PoE
Cube 60G ac
Product image
Product image
Product image
Product image
Product image
Product image thumbnail
If you are managing networks in a large, busy area (like a park or a stadium), then you have probably experienced all kinds of problems – massive interference, signal loss during bad weather, etc. What if we told you that a single device can solve all these problems? The brand new Cube 60G ac is the simple solution you have been looking for!
It can easily cover a distance of 800 meters and reach fiber-like speed. The 60 GHz frequency is unaffected by the crowded wireless spectrum, it offers high speed and capacity. Traditional 60 GHz devices, however, can have limited connectivity during bad weather. But not the Cube 60G ac! It features an automatic 5 GHz backup connection, so you don’t have to worry about any downtime. The Сube form-factor has been designed with function and durability in mind. And it attracts less unwanted attention due to its size and shape.
Video thumbnail
Specification
Specifications
  • Product code CubeG-5ac60ad
  • Suggested price $135.00
  • Architecture ARM 32bit
  • CPU IPQ-4019
  • CPU core count 4
  • CPU nominal frequency 716 MHz
  • CPU Threads count 4
  • Dimensions 130 x 130 x 132 mm
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 256 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 9 W
  • Max power consumption without attachments 9 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 12-57 V
Wireless specifications
  • Wireless 5 GHz Max data rate 433 Mbit/s
  • Wireless 5 GHz Number of chains 1
  • Wireless 5 GHz standards 802.11a/n/ac
  • Antenna gain dBi for 5 GHz 11.5
  • Wireless 5 GHz chip model IPQ-4019
  • Wireless 5 GHz generation Wi-Fi 5
Ethernet
  • 10/100/1000 Ethernet ports 1
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP IP54
Included parts
Note
Wireless Specification
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for arm devices.
System Package
More in download page
Related Products
