Skip to main content
Discontinued
wAP BE
Small weatherproof wireless access point for mounting on a ceiling, wall or pole. In black
Outdoors
PoE
wAP BE
Product image
Product image
Product image thumbnail
The wAP is a small weatherproof wireless access point for your mobile devices - perfect for installation outside your house, in the garden, on your porch or anywhere else where you need wireless access from your phone or computer.
The device has one 10/100 Ethernet port, it supports 802.11b/g/n wireless standards. It looks unobtrusive and sleek, available in two colours - black (RBwAP2nD-BE) and white (RBwAP2nD).
The wAP is weatherproof and can be fixed to any external wall from the inside of the case - so that it is securely attached to it's mounting location. The bottom door can also be secured with a special screw, which can only be opened by the owner.
It is also possible to run the Ethernet cable directly behind the unit, to inside the wall, there is a special opening on the back of the case. This way, the unit doesn’t attract attention and blends into any environment.
Specification
Specifications
  • Product code RBwAP2nD-BE
  • Suggested price $45.00
  • Architecture MIPSBE
  • CPU QCA9531
  • CPU core count 1
  • CPU nominal frequency 650 MHz
  • Dimensions 185 x 85 x 30 mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
  • Tested ambient temperature -40C to +70C
Wireless capabilities
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 2
  • Wireless 2.4 GHz chip model QCA9531
  • Wireless 2.4 GHz generation Wi-Fi 4
Ethernet
  • 10/100 Ethernet ports 1
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 11-57 V
  • Max power consumption 4 W
  • PoE in 802.3af/at
  • PoE in input Voltage 11-57 V
Certification & Approvals
  • Certification FCC, IC
  • IP IP20
Included parts
Note
Wireless Specification
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for mipsbe devices.
More in download page
Related Products
