Skip to main content
Discontinued
SXT HG5
17dbi integrated AP/Backbone/CPE, Gigabit Ethernet
Outdoors
PoE
SXT HG5
Product image
Product image
Product image thumbnail
SXTG HG is a High Gain, High Power wireless device designed and manufactured by MikroTik.
It is equipped with 5GHz 17dBi 24 degree antenna, Gigabit Ethernet port and RouterOS L4 license (can be used as AP, Backbone or CPE).
It is powered by our new generation AR9344 CPU, which makes it even more powerful, to ensure you get the maximum throughtput.
Unit comes complete with SXT, PoE injector, power supply and mounting kit.
- RBSXTG-5HPnD-HGr2-US (USA) is factory locked for 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
- RBSXTG-5HPnD-HGr2 (International) supports 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
Specification
Specifications
  • Product code RBSXTG-5HPnD-HGr2
  • Suggested price $95.00
  • Architecture MIPSBE
  • CPU AR9344
  • CPU core count 1
  • CPU nominal frequency 600 MHz
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -30°C to 70°C
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 11 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 6-30 V
Wireless specifications
  • Wireless 5 GHz Max data rate 300 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n
  • Antenna gain dBi for 5 GHz 16.5
  • Wireless 5 GHz chip model AR9344
  • Wireless 5 GHz generation Wi-Fi 4
Ethernet
  • 10/100/1000 Ethernet ports 1
Peripherals
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification FCC
Included parts
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
System Package
More in download page
Related Products
