Skip to main content
Discontinued
RB911G-2HPnD
600Mhz CPU, 32MB RAM, 1xGigabit Ethernet, onboard 2.4Ghz wireless, RouterOS L3
Outdoors
PoE
RB911G-2HPnD
Product image
Product image thumbnail
The RB911G-2HPnD is a small wireless router with an integrated high power 2.4GHz wireless card. The Gigabit port helps to utilize the full potential of 802.11n wireless speeds.
It has built in 16kV ESD protection on both the Ethernet and the MMCX ports.
Specification
Specifications
  • Product code RB911G-2HPnD
  • Suggested price $49.00
  • Architecture MIPSBE
  • CPU AR9342
  • CPU core count 1
  • CPU nominal frequency 600 MHz
  • Dimensions 105x105mm
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 128 MB
  • Storage type NAND
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 6-30 V
  • Max power consumption 10 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 6-30 V
Wireless specifications
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Wireless 2.4 GHz chip model AR9342
  • Wireless 2.4 GHz generation Wi-Fi 4
Ethernet
  • 10/100/1000 Ethernet ports 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification FCC, IC
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
More in download page
