Skip to main content
Discontinued
CRS226-24G-2S+RM
24x Gigabit Ethernet Smart Switch, 2x SFP+ cages, LCD, 400MHz CPU, 64MB RAM, 1U rackmount case, RouterOS L5
PoE
SFP/SFP+
CRS226-24G-2S+RM
Product image
Product image thumbnail
The Cloud Router Switch CRS226-24G-2S+ is now available also in a 1U rackmount case, product code CRS226-24G-2S+RM. It is a fully functional Layer 3 switch powered by RouterOS. All the specific switch configuration options are available in a special switch menu. But if you want, ports can be removed from the switch configuration and used for routing purposes. It has 24 Gigabit ports and two SFP+ cages for 10G connectivity (first SFP port supports 1.25G/10G modules, second port only 10G modules).
Specification
Specifications
  • Product code CRS226-24G-2S+RM
  • Suggested price $299.00
  • Architecture MIPSBE
  • CPU QCA8519
  • CPU core count 1
  • CPU nominal frequency 400 MHz
  • Switch chip model QCA8519-AC2C
  • Dimensions 443x145x45mm
  • RouterOS license 5
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 128 MB
  • Storage type NAND
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 8-30 V
  • Supported Voltage 8-30V on Ether1
  • Max power consumption 21 W
  • Max power consumption without attachments 21W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 8-30 V
Ethernet
  • 10/100/1000 Ethernet ports 24
Fiber
  • SFP DDMI Yes
  • SFP+ ports 2
Peripherals
  • Serial console port RJ45
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for mipsbe devices.
System Package
More in download page
