Skip to main content
Discontinued
CRS210-8G-2S+IN
8x Gigabit Smart Switch, 2x SFP+ cages, LCD, 400MHz CPU, 64MB RAM, Metal desktop case, RouterOS L5, supports 10-57V, 802.3af/at
PoE
SFP/SFP+
CRS210-8G-2S+IN
Product image
Product image
Product image thumbnail
Cloud Router Switch 210-8G-2S+IN is new “small size low cost” member of our CRS series. It comes with eight Gigabit Ethernet ports and two SFP+ cages for 10G connectivity (first port supports 1.25G/10G modules, second port only 10G modules). Product supports 10-57V DC.
Our CRS series combines the best features of a fully functional router and a Layer 3 switch, is powered by the familiar RouterOS. All the specific Switch configuration options are available in a special Switch menu, but if you want, ports can be removed from the switch configuration, and used for routing purposes.
Box includes- Switch, 24v 0.8A power supply, rackmount ears
Specification
Specifications
  • Product code CRS210-8G-2S+IN
  • Suggested price $229.00
  • CPU QCA8519
  • CPU core count 1
  • CPU nominal frequency 400 MHz
  • Switch chip model QCA8519-AC2C
  • Dimensions 200x144x47mm (case)
  • RouterOS license 5
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 128 MB
  • Storage type NAND
Powering
  • 802.3af support Yes
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 10-57 V
  • Max power consumption 13 W
  • Max power consumption without attachments 13W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 10-57 V
Ethernet
  • 10/100/1000 Ethernet ports 8
Fiber
  • SFP+ ports 2
Peripherals
  • Serial console port RJ45
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
