Skip to main content
RB5009UPr+S+OUT
An outdoor version of our best-selling heavy-duty PoE router. Extensive power redundancy for the best price! 7x Gigabit Ethernet ports, 1x 2.5 Gigabit Ethernet, 10G SFP+, 1GB of RAM, 1GB NAND, modern quad-core CPU, 9 (!) powering options, durable IP66 waterproof enclosure.
ARM64
Quad-core CPU
2.5G
IP 66
Outdoors
PoE
ROS v7
SFP/SFP+
RB5009UPr+S+OUT
Product image
Product image
Product image
Product image
Product image
Product image
Product image
Product image thumbnail
As a network administrator, you never know when the next windstorm, lightning, flood, heatwave, or a power outage will strike. But with the right tools you can protect your network from most troubles! Here’s our wishlist for the perfect tool:
  • easy to deploy
  • works well in ANY weather
  • provides extensive power redundancy
  • can be connected via most common networking interfaces
  • has a CPU that is strong enough to take full advantage of the most powerful
  • networking software in the world – RouterOS v7
  • doesn’t cost a fortune
Adding an IP66-rated waterproof enclosure to the RB5009 series allowed us to meet all the requirements! The brand new RB5009UPr+S+OUT is a compact, cost-effective solution that will revolutionize your network tower setups. You’re getting one of the most powerful outdoor networking devices for the best price on the market!
Like the indoor version, this RB5009 has 7x Gigabit Ethernet ports, one 2.5 Gigabit Ethernet port, a 10G SFP+ cage, and a full sized USB3 port!
When we say “extensive power redundancy”, we really mean it: the unit offers 9 possible ways of powering. There’s a 2-pin (5.08mm 1x2pin) power connector on the front, as well as PoE-in and PoE-out on all eight Ethernet ports. The board can use any of these sources to power itself, choosing the one with the highest voltage when multiple sources are available. RB5009 takes up to 21W to power itself. If you’re using PoE-in, the board will stay on even if 8 of your 9 power sources suddenly go down. Unprecedented redundancy!
All power options support a wide voltage range of 24 – 57 V. However, you can not mix the voltages.
Each PoE-out port can supply up to 25W of power. All the ports combined are limited to 130W, which should be enough for most setups. (Note that the included PSU is capable of 96W total, so for maximum output, a different PSU will be needed). You can specify maximum available power from your power sources manually, if necessary. If you’re using PoE-out to power other devices, you have to provide power via the 2-pin (5.08mm 1x2pin) connector to power those.
This product also features single voltage PoE-out – it can either be 802.3at/af compatible OR low-voltage PoE-out. That is determined by the voltage on the 2-pin connector, as no voltage conversion is done on this board.
When it comes to processing power and available use-cases, this router can do it all: PPPoE termination, DHCP to customers, Local Queuing, MPLS Push/Pop/Swap and MPLS Forwarding, VPLS/VXLAN Termination, Hardware bridging, and so much more!
The RB5009 series keep redefining affordable reliability for small, medium, and even large ISPs!
Video thumbnail
Specification
Specifications
  • Product code RB5009UPr+S+OUT
  • Suggested price $319.00
  • Architecture ARM 64bit
  • CPU 88F7040
  • CPU core count 4
  • CPU nominal frequency 350-1400 (auto) MHz
  • CPU Threads count 4
  • Switch chip model 88E6393
  • RouterOS license 5
  • Operating System RouterOS v7
  • Size of RAM 1 GB
  • Storage size 1 GB
  • Storage type NAND
Powering
  • Number of DC inputs 2 (PoE-IN, 2-pin terminal)
  • 2-pin terminal input Voltage 24-57 V
  • Max power consumption 150 W
  • Max power consumption without attachments 15 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 24-57 V
PoE-out
  • PoE-out ports Ether1-Ether8
  • PoE out 802.3af/at
  • Low voltage PoE-Out current limit 900 mA
  • High voltage PoE-Out current limit 440 mA
  • Max total out (A) 2.59 A
  • Total output current 2.28
  • Total output power 130
Ethernet
  • 10/100/1000 Ethernet ports 7
  • Number of 1G Ethernet ports with Reverse PoE (PoE-in) 7
  • Number of 2.5G Ethernet ports 1
  • Number of 2.5G Ethernet ports with PoE-out 1
Fiber
  • SFP+ ports 1
Peripherals
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB 3.0 type A
  • Max USB current (A) 1.5
Other
  • CPU temperature monitor Yes
  • Current Monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP 66
Included parts
Note
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.20.5 download files for arm64 devices.
System Package
More
Netinstall:
More in download page
Related Products
