Skip to main content
CRS328-4C-20S-4S+RM
Smart Switch, 20 x SFP cages, 4 x SFP+ cages, 4 x Combo ports (Gigabit Ethernet or SFP), 800MHz CPU, 512MB RAM, 1U rackmount case, Dual Power Supplies, RouterOS L5 or SwitchOS (Dual Boot)
ARM
Combo ports
Dual boot
SFP/SFP+
CRS328-4C-20S-4S+RM
Product image
Product image
Product image thumbnail
The CRS328-4C-20S-4S+RM is a 28 independent port switch with a combo group. This device has twenty SFP ports, four SFP+ ports for 10G modules and four combo ports, where you can choose to use SFP or RJ45 ports from the combo group. These ports can also be software selected, so if you have plugged in all eight cables, you can use scripting, to decide which four combo ports will be active.
The device comes in a 1U rackmount case with two 100-240 V power supplies with failover functionality. A RJ45 console port is available for management and debugging, and a mode button can be customised to execute any RouterOS commands.
The device has a “Dual boot” feature that allows you to choose between two operating systems - RouterOS or SwOS.
Specification
Specifications
  • Product code CRS328-4C-20S-4S+RM
  • Suggested price $449.00
  • Architecture ARM 32bit
  • CPU 98DX3236
  • CPU core count 2
  • CPU nominal frequency 800 MHz
  • Switch chip model 98DX3236
  • Dimensions 443 x 194 x 44 mm
  • RouterOS license 5
  • Operating System RouterOS / SwitchOS
  • Size of RAM 512 MB
  • Storage size 16 MB
  • Storage type FLASH
  • Tested ambient temperature -20°C to 60°C
Powering
  • Number of AC inputs 2
  • AC input range 100-240
  • Number of PSU slots 2
  • Frequency (Hz) 50-60
  • Max power consumption 43 W
  • Cooling type 2 fans
Ethernet
  • Ethernet Combo ports 4
Fiber
  • SFP ports 20
  • SFP+ ports 4
Peripherals
  • Serial console port RJ45
Other
  • CPU temperature monitor Yes
  • Voltage Monitor Yes
  • Mode button Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.20.6 download files for arm devices.
Latest SwitchOS release v2.18 download files for css328 devices.
More in download page
