Products
Products
    XS+DA0001 Direct attach cable that supports not only SFP 1G and SFP+ 10G, but also the 25G SFP28 standard!
    We are releasing new direct attach cables that support not only SFP 1G and SFP+ 10G, but also the 25G SFP28 standard! With the new direct attach cables you get more features for the same price!
    This is highly cost-effective way to connect two SFP/SFP+/SFP28 devices (for example two units of our new CCR2004-1G-12S+2XS) for very short distances, within racks and across adjacent racks.
    They provide a low cost, low power and low latency interconnect solution for 25-Gigabit Ethernet, Fiber Channel and other industry standards, and are direct attached compliant and fully conform to the SFP+ MSA specifications.
    Two versions are available- XS+DA0001 (1m) and XS+DA0003 (3m)
     Send purchase questions
    Product specifications
    Details
    Product code XS+DA0001
    Cable length 1m
    Data Rate 1G / 10G / 25G
    Suggested price $29
    SFP compatibility listOpen
    High resolution images
    Related products
