Skip to main content
Discontinued
RB3011UiAS-RM
1U rackmount, 10xGigabit Ethernet, SFP, USB 3.0, LCD, PoE out on port 10, 2x1.4GHz CPU, 1GB RAM, RouterOS L5
ARM
PoE
ROS v7
SFP/SFP+
RB3011UiAS-RM
Product image
Product image
Product image thumbnail
The RB3011 is a new multi port device, our first to be running an ARM architecture CPU for higher performance than ever before. The RB3011 has ten Gigabit ports divided in two switch groups, an SFP cage and for the first time a SuperSpeed full size USB 3.0 port, for adding storage or an external 3G/4G modem.
RB3011UiAS-RM Unit comes with 1U rackmount enclosure, a touchscreen LCD panel, a serial console port and PoE output functionality on the last Ethernet port.
Specification
Specifications
  • Product code RB3011UiAS-RM
  • Suggested price $179.00
  • Architecture ARM 32bit
  • CPU IPQ-8064
  • CPU core count 2
  • CPU nominal frequency 1.4 GHz
  • CPU Threads count 2
  • Switch chip model QCA8337
  • Dimensions 443 x 92 x 44 mm
  • RouterOS license 5
  • Operating System RouterOS v7
  • Size of RAM 1 GB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -20°C to 70°C
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 10-30 V
  • Max power consumption 30 W
  • Max power consumption without attachments 10 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 10-30 V
PoE-out
  • PoE-out ports Ether10
  • PoE out Passive PoE
  • Low voltage PoE-Out current limit 600 mA
  • Max total out (A) 600 mA
Ethernet
  • 10/100/1000 Ethernet ports 10
Fiber
  • SFP ports 1
Peripherals
  • Serial console port RJ45
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB 3.0 type A
  • Max USB current (A) 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP20
Included parts
Note
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.2 download files for arm devices.
More in download page
