Skip to main content
Discontinued
LDF LTE6 kit
This outdoor wireless system with a built-in antenna can provide a connection even in the most remote locations. Tiny, powerful, can be used with any satellite TV dish with an offset mount.
IP 68
LTE Cat6
Mini PCI-e
Outdoors
PoE
LDF LTE6 kit
Product image
Product image
Product image
Product image
Product image thumbnail
LDF LTE6 kit is a device for extremely remote locations that are within cellular network coverage. Attach it to any satellite TV dish (NOT included) and the dish will act as a reflector, greatly amplifying the signal.
Using large enough dishes, it is possible to obtain antenna amplification of 30 dBi or more. That means – Internet connectivity is possible even in areas, where you would usually have no mobile connectivity at all. Stormy weather is not a problem either – with a solid IP68 rating LDF LTE6 kit can withstand dust, dirt and sand, as well as temporary immersion in water.
LDF LTE6 kit features a CAT6 LTE modem, which enables carrier aggregation and allows the device to use multiple bands at the same time. A huge advantage when there are a lot of LTE users in the area. It provides better responsiveness and
higher efficiency for weaker signal situations in the countryside. We have seen Internet speed doubling in rural areas after switching to CAT6.
Specification
Specifications
  • Product code RBLDFR&R11e-LTE6
  • Suggested price $169.00
  • Architecture MIPSBE
  • CPU QCA9531
  • CPU core count 1
  • Dimensions 94 x 94 x 150 mm
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
  • Tested ambient temperature -30°C to 60°C
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 6 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 12-57 V
Mobile
  • 2G Category Class12
  • 2G bands 2 (1900MHz)
    3 (1800MHz)
    5 (850MHz)
    8 (900MHz)
  • 3G Category R7 (21Mbps Downlinks, 5.76Mbps Uplink) / R8 (42.2Mbps Downlink, 5.76Mbps Uplink)
  • 3G bands 1 (2100MHz)
    2 (1900MHz)
    5 (850MHz)
    8 (900MHz)
  • LTE Category 6 (300Mbit/s Downlink, 50Mbit/s Uplink)
  • LTE FDD bands 1 (2100MHz)
    2 (1900MHz)
    3 (1800MHz)
    5 (850MHz)
    7 (2600MHz)
    8 (900 MHz)
    12 (700MHz)
    17 (700MHz)
    20 (800MHz)
    25 (1900MHz)
    26 (850MHz)
  • LTE TDD bands 38 (2600MHz)
    39 (1900MHz)
    40 (2300MHz)
    41n (2500MHz)
  • TAC 35666210
Wireless specifications
  • Antenna gain 8 dBi
Ethernet
  • 10/100 Ethernet ports 1
Peripherals
  • MiniPCI-e slots 1
Other
  • Mode button Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP68
Included parts
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for mipsbe devices.
System Package
More in download page
Related Products
