Skip to main content
Discontinued
LDF 5 ac
Dual chain 5GHz system with Gigabit Ethernet and 802.11ac support for long distance links with satellite offset dish antennas
ARM
Quad-core CPU
IP 54
Outdoors
PoE
LDF 5 ac
Product image
Product image
Product image
Product image
Product image thumbnail
The LDF (Lite Dish Feed) is an outdoor wireless system with a built in antenna, meant to be installed on satellite offset dish antennas. The dish will act as a reflector, amplifying the signal.
This means you can use any available satellite TV dish with an offset mount to quickly deploy powerful long range wireless links. The offset mount is universal at 40 mm diameter, and the LDF can easily be placed inside it. Since the LDF itself is a tiny little package, it makes shipping and deployment simple and low cost.
LDF 5 ac is equipped with a Gigabit port and supports 802.11ac for higher throughput.
- LDF 5 ac-US (USA) is factory locked for 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
- LDF 5 ac (International) supports 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
Specification
Specifications
  • Product code RBLDFG-5acD
  • Suggested price $68.00
  • Architecture ARM 32bit
  • CPU IPQ-4018
  • CPU core count 4
  • CPU nominal frequency 716 MHz
  • CPU Threads count 4
  • Dimensions 84mm x 84mm x 115mm
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 256 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 8 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 10-28 V
Wireless specifications
  • Wireless 5 GHz Max data rate 867 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n/ac
  • Antenna gain dBi for 5 GHz 9
  • Wireless 5 GHz chip model IPQ-4018
  • Wireless 5 GHz generation Wi-Fi 5
Ethernet
  • 10/100/1000 Ethernet ports 1
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP IP54
Included parts
Note
Wireless Specification
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for arm devices.
System Package
More in download page
Related Products
