Skip to main content
Discontinued
SXT LTE
SXT CPE with 3 (1800MHz) and 7 (2600MHz) LTE FDD band support, 9dBi 60 degree antenna, 400Mhz CPU, 64MB RAM, enclosure, PoE and PSU (RouterOS L3)
LTE Cat3
Outdoors
PoE
SXT LTE
Product image
Product image thumbnail
The SXT LTE (product code RBSXTLTE3-7) is a special variant of our popular SXT device, and doesn’t include a 802.11 wireless device. Instead, it has a built in high quality LTE Category 3 modem for speeds of up to 100Mbit/s downlink and 50 Mbit/s uplink.
A perfect device for remote locations that are within cellular network coverage. Due to it’s professional LTE chip and high gain antenna, it can provide connectivity for your building even where cell phones can’t.
The signal LEDs show LTE signal level for easy positioning. The SXT LTE supports the popular LTE FDD bands 3 (1800MHz) and 7 (2600MHz), has a miniSIM slot and is not backwards compatible with older networks.
Specification
Specifications
  • Product code RBSXTLTE3-7
  • Suggested price $129.00
  • Architecture MIPSBE
  • CPU AR7241
  • CPU core count 1
  • CPU nominal frequency 400 MHz
  • Dimensions 140x140x105mm
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 128 MB
  • Storage type NAND
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 5 W
  • Max power consumption without attachments 5W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 11-57 V
Mobile
  • LTE Category 3 (100Mbit/s Downlink, 50Mbit/s Uplink)
  • LTE FDD bands 3 (1800MHz)
    7 (2600MHz)
  • TAC 35615906
Wireless specifications
  • Antenna gain 9
Ethernet
  • 10/100 Ethernet ports 1
Peripherals
  • Number of SIM slots 1 Modem (Mini SIM)
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Included parts
Note
Ethernet test results
Download
Latest RouterOS stable release v7.25.1 download files for mipsbe devices.
More in download page
