Skip to main content
Discontinued
SEXTANT G
18dBi integrated CPE/Backbone, Gigabit Ethernet
Outdoors
PoE
SEXTANT G
Product image
Product image thumbnail
The SEXTANT is a 18dBi 5GHz antenna with a built in RB911G router. It has two polarizations to give you all benefits of 2x2 MIMO in 802.11n.
Inside is the high power RB911 dual chain wireless device, with high performance, high output power, and a Gigabit Ethernet port, to fully
utilize the benefit of 802.11n high speed wireless.
Easy to use and quick to deploy, SEXTANT is ideal for point to point links.
Package contains SEXTANTG5PHnD, mounting kit, PoE injector, power adapter
- RBSEXTANTG5HPnD-US (USA) is factory locked for 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
- RBSEXTANTG5HPnD (International) supports 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
Specification
Specifications
  • Product code RBSEXTANTG-5HPnD
  • Suggested price $110.00
  • Architecture MIPSBE
  • CPU AR9342
  • CPU core count 1
  • CPU nominal frequency 600 MHz
  • Dimensions Ø250mm, height 90mm, 830g
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 64 MB
  • Storage type NAND
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 13.8 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 10-28 V
Wireless specifications
  • Wireless 5 GHz Max data rate 300 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n
  • Antenna gain dBi for 5 GHz 18
  • Wireless 5 GHz chip model AR9342
  • Wireless 5 GHz generation Wi-Fi 4
Ethernet
  • 10/100/1000 Ethernet ports 1
Other
  • Beeper Yes
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for mipsbe devices.
More in download page
