Skip to main content
Discontinued
OmniTIK 5 PoE
7.5dBi Integrated AP, 5GHz Dual chain, 5xEthernet ports with PoE output
IP 54
Outdoors
PoE
OmniTIK 5 PoE
Product image
Product image
Product image thumbnail
OmniTIK is a weatherproof outdoor AP with dual-polarized omni antennas - the perfect companion for our SXT, or for any other 5GHz 802.11a/n standard device. Weatherproof, durable and ready to use. It has ve 10/100 Ethernet ports, PoE support and a built-in 1000mW 802.11a/n wireless radio. It supports Nv2 TDMA technology with up to 200Mbit aggregate throughput.
LED signal indicators on it’s back are fully customizable, show Ethernet activity or wireless signal - or any other information from RouterOS. The USB port gives the ability to connect a 3G modem or a storage drive.
The OmniTIK UPA also features power output on it’s ethernet ports. Ports 2-5 can power other PoE capable devices with the same voltage as applied to the unit. Less power adapters to worry about.
Box contains OmniTik UPA-5HnD, mounting loops, PoE injector, 24v 2.5A power adapter
- RBOmniTikUPA-5HnD-US (USA) is factory locked for 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
- RBOmniTikUPA-5HnD (International) supports 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
Specification
Specifications
  • Product code RBOmniTikUPA-5HnD
  • Suggested price $99.00
  • Architecture MIPSBE
  • CPU AR9344
  • CPU core count 1
  • CPU nominal frequency 600 MHz
  • Switch chip model AR9344
  • Dimensions 368x125x55mm
  • RouterOS license 5
  • Operating System RouterOS
  • Size of RAM 128 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 59 W
  • Max power consumption without attachments 11 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 11-30 V
PoE-out
  • PoE-out ports Ether2-Ether5
  • PoE out Passive PoE
  • Low voltage PoE-Out current limit 1 A
  • Max total out (A) 2 A
Wireless specifications
  • Wireless 5 GHz Max data rate 300 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n
  • Antenna gain dBi for 5 GHz 7.5
  • Wireless 5 GHz chip model AR9344
  • Wireless 5 GHz generation Wi-Fi 4
Ethernet
  • 10/100 Ethernet ports 5
Peripherals
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP IP54
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
System Package
More in download page
Related Products
