Skip to main content
Discontinued
RB751G-2HnD
perfect SOHO AP five Gigabit Ethernet 1000mW 2.4Ghz wireless USB
PoE
RB751G-2HnD
Product image
Product image thumbnail
The RB751G-2HnD is the wireless SOHO Gigabit AP you have been waiting for. It has five Gigabit Ethernet ports, one USB 2.0 port and a high power 2.4GHz 30dBi/1000mW 802.11b/g/n wireless AP with antennas built in.
It’s also possible to connect an external MMCX antenna to replace one of the built in antennas. The device is very small and will look good in any home or office, wall mounting anchor holes are provided.
Package contains RouterBOARD 751G-2HnD in a plastic case and power adapter.
Specification
Specifications
  • Product code RB751G-2HnD
  • Suggested price $79.95
  • Architecture MIPSBE
  • CPU AR7242
  • CPU core count 1
  • CPU nominal frequency 400 MHz
  • Dimensions 113x138x29mm
  • RouterOS license 4
  • Operating System RouterOS
  • Storage size 64 MB
  • Storage type NAND
  • Tested ambient temperature -20C...+50C
Wireless capabilities
  • Antenna gain dBi for 2.4 GHz 2.5
Ethernet
  • 10/100/1000 Ethernet ports 5
Peripherals
  • Number of USB ports 1
Powering
  • Number of DC inputs 1
  • PoE in Passive PoE
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for mipsbe devices.
More in download page
