Skip to main content
Discontinued
RB2011iL-RM
1U rackmount, 5xEthernet, 5xGigabit Ethernet, PoE out on port 10, 600MHz CPU, 64MB RAM, RouterOS L4
PoE
RB2011iL-RM
Product image
Product image
Product image thumbnail
The RB2011 is a low cost multi port device series. Designed for indoor use, and available in many different cases, with a multitude of options.
The RB2011 is powered by RouterOS, a fully featured routing operating system which has been continuously improved for fifteen years. Dynamic routing, hotspot, firewall, MPLS, VPN, advanced quality of service, load balancing and bonding, real-time configuration and monitoring - just a few of the vast number of features supported by RouterOS.
The RB2011iL-RM includes a new feature - power injector on Ethernet port 10 - it can power other PoE capable devices with the same voltage as applied to the unit. Less power adapters and cables to worry about! Maximum load on the port is 500mA. It is powered by the new Atheros 600MHz 74K MIPS network processor, has 64MB of RAM and a Level4 RouterOS license, as well as five Gigabit Ethernet ports and five Fast Ethernet ports for unbeliveable USD 99!
RouterBOARD 2011iL-RM comes with 1U rackmount enclosure and power supply.
Specification
Specifications
  • Product code RB2011iL-RM
  • Suggested price $99.00
  • Architecture MIPSBE
  • CPU AR9344
  • CPU core count 1
  • CPU nominal frequency 600 MHz
  • Switch chip model AR8327-BL1A-R
  • Dimensions 443 x 92 x 44 mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -40°C to 60°C
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 8-30 V
  • Max power consumption 18 W
  • Max power consumption without attachments 6 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 8-30 V
PoE-out
  • PoE-out ports Ether10
  • PoE out Passive PoE
  • Low voltage PoE-Out current limit 510 mA
  • Max total out (A) 510 mA
Ethernet
  • 10/100 Ethernet ports 5
  • 10/100/1000 Ethernet ports 5
Other
  • Beeper Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP20
Included parts
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for mipsbe devices.
System Package
More in download page
