Products
Products
    SXT LTE6 kit-US Affordable connectivity in remote areas. Even if your phone has no reception at all, SXT LTE6 kit can deliver due to its advanced LTE chip design and high-gain antenna. US carrier-certified! (AT&T, T-Mobile)
    This device is an absolute staple of affordable connectivity in remote areas. Even if your phone has no reception at all, our SXT LTE6 kit can still deliver due to its advanced LTE chip design and high-gain antenna.
    There are two Ethernet ports. Ethernet port #1 has PoE-in. And Ethernet #2 has PoE-out. You can use it to power another device. Fewer cables to worry about in your sweet cabin in the woods!
    We’ve included two Micro-SIM slots – for backup. It never hurts to have extra options when it comes to mobile network coverage. Also, the Category 6 LTE modem enables carrier aggregation, allowing SXT to use multiple LTE bands simultaneously. That’s a huge advantage when there are a lot of mobile users in the area. It offers better responsiveness in a crowded environment. And higher efficiency for weaker signal situations in the countryside. Win-win! We have seen Internet speed doubling in rural areas after switching to CAT6, so there is no need to wait for cable network expansions.
    When it comes to powering, SXT LTE6 kit supports a wide voltage range of 18-57V with full 802.3af/at compliance.
     Send purchase questions
    Specifications
    Details
    Product code SXTR&EP06-A
    Architecture MIPSBE
    CPU QCA9531
    CPU core count 1
    CPU nominal frequency 650 MHz
    Switch chip model QCA9531
    RouterOS license 3
    Operating System RouterOS
    Size of RAM 64 MB
    Storage size 16 MB
    Storage type FLASH
    MTBF Approximately 200'000 hours at 25C
    Tested ambient temperature -40°C to 60°C
    Suggested price $169.00
    Powering
    Details
    Number of DC inputs 1 (PoE-IN)
    Max power consumption 21 W
    Max power consumption without attachments 5 W
    Cooling type Passive
    PoE in 802.3af/at
    PoE in input Voltage 12-57 V
    PoE-out
    Details
    PoE-out ports Ether2
    PoE out Passive PoE up to 57V
    Max out per port output (input 18-30 V) 600 mA
    Max out per port output (input 30-57 V) 400 mA
    Max total out (A) 600 mA
    Total output current 600mA
    Mobile
    Details
    3G Category R8 (42.2Mbps Downlink, 5.76Mbps Uplink)
    3G bands 2 (1900MHz) / 5 (850MHz) / 4 (1700MHz)
    LTE Category 6 (300Mbit/s Downlink, 50Mbit/s Uplink)
    MIMO DL 2x2
    LTE FDD bands 2 (1900MHz) / 4 (1700MHz) / 5 (850MHz) / 7 (2600MHz) / 12 (700MHz) / 13 (700 MHz) / 25 (1900MHz) / 26 (850MHz) / 30 (2300 MHz) / 66 (1700MHz) / 29 (700 MHz)
    TAC 01611100
    Ethernet
    Details
    10/100 Ethernet ports 2
    Peripherals
    Details
    Number of SIM slots 2 Modem (Micro SIM)
    MiniPCI-e slots 1
    Other
    Details
    Mode button Yes
    Included parts
    BrochureOpen
    Quick GuideOpen
    User ManualOpen
    RouterOS current releaseDownload
    Block DiagramOpen
    RouterOS software manualOpen
    High resolution images
    Ethernet test results
    SXTR&EP06-AQCA9531 100M two port test
    ModeConfiguration1518 byte512 byte64 byte
    kppsMbpskppsMbpskppsMbps
    Bridgingnone (fast path)16.3197.947.0192.5297.6152.4
    Bridging25 bridge filter rules16.3197.947.0192.580.441.2
    Routingnone (fast path)16.3197.947.0192.5233.1119.3
    Routing25 simple queues16.3197.947.0192.5131.467.3
    Routing25 ip filter rules16.3197.947.0192.549.125.1
    1. All tests are done with Xena Networks specialized test equipment (XenaBay),and done according to RFC2544 (Xena2544)
    2. Max throughput is determined with 30+ second attempts with 0,1% packet loss tolerance in 64, 512, 1518 byte packet sizes
    3. Test results show device maximum performance, and are reached using mentioned hardware and software configuration, different configurations most likely will result in lower results
    The device has an operating system preinstalled and licensed. No separate purchase is necessary and the product is ready to use. The device includes free software updates for the life of the product or a minimum of 5 years starting from date of purchase..
    Related products
