Skip to main content
RB4011iGS+RM
Powerful 10xGigabit port router with a Quad-core 1.4Ghz CPU, 1GB RAM, SFP+ 10Gbps cage and desktop case with rack ears
ARM
Quad-core CPU
PoE
ROS v7
SFP/SFP+
RB4011iGS+RM
Product image
Product image
Product image
Product image
Product image
Product image
Product image thumbnail
RB4011 series - amazingly powerful routers with ten Gigabit ports, SFP+ 10Gbps interface and IPsec hardware acceleration for a great price!
The RB4011 uses a quad core Cortex A15 CPU, same as in our carrier grade RB1100AHx4 unit. The unit is equipped with 1GB of RAM, can provide PoE output on port #10 and comes with a compact and professional looking solid metal enclosure in matte black.
RB4011iGS+RM (Ethernet model) includes two rackmount ears that will securely fasten the unit in a standard 1U rack space.
Specification
Specifications
  • Product code RB4011iGS+RM
  • Suggested price $219.00
  • Architecture ARM 32bit
  • CPU AL21400
  • CPU core count 4
  • CPU nominal frequency auto (533 - 1900) MHz
  • CPU Threads count 4
  • Switch chip model RTL8367SB
  • Dimensions 228 x 120 x 30 mm
  • RouterOS license 5
  • Operating System RouterOS v7
  • Size of RAM 1 GB
  • Storage size 512 MB
  • Storage type NAND
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 12-57 V
  • Max power consumption 33 W
  • Max power consumption without attachments 18 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 18-57 V
PoE-out
  • PoE-out ports Ether10
  • PoE out Passive PoE up to 57V
  • Low voltage PoE-Out current limit 600 mA
  • High voltage PoE-Out current limit 420 mA
  • Max total out (A) 600 mA
Ethernet
  • 10/100/1000 Ethernet ports 10
Fiber
  • SFP+ ports 1
Peripherals
  • Serial console port RJ45
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP20
Included parts
Note
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.20.6 download files for arm devices.
System Package
More in download page
