Skip to main content
CRS354-48P-4S+2Q+RM
The 48 port champion you’ve been waiting for - now with PoE-out!
Dual boot
40G
PoE
ROS v7
SFP/SFP+
CRS354-48P-4S+2Q+RM
Product image
Product image
Product image
Product image
Product image
Product image thumbnail
If you are looking for a single switch that will put your network setup ahead of the curve and power all the necessary devices – look no further! The new CRS354-48P-4S+2Q+RM is an effective and adaptable rackmount solution for managing networks in the most demanding environments. Unlike many other switches out there, our products are made with the system administrator in mind.
This powerful switch has 48 x 1G RJ45 ports and 4 x 10G SFP+ ports. There are also 2 x 40G QSFP+ ports for extremely fast fiber connections or linking with other 40 Gbps devices. All 48 Ethernet ports offer different power output options: Passive PoE, low voltage PoE, 802.3af/at (Type 1 “PoE” / Type 2 “PoE+”) with auto-sensing, making this switch the easiest solution to power even the largest setups. We have included a mighty power supply that can provide 750 W of power – this switch can handle a lot. And there is a special bracket for easy cable management.
CRS354-48P-4S+2Q+RM is extremely functional, and it has the best price-point on the market – it will make the perfect addition to a professional setup.
The total non-blocking throughput is 168 Gbps, switching capacity is 336 Gbps and the forwarding rate reaches 235 Mpps.
Specification
Specifications
  • Product code CRS354-48P-4S+2Q+RM
  • Suggested price $999.00
  • Architecture MIPSBE
  • CPU QCA9531
  • CPU core count 1
  • CPU nominal frequency 650 MHz
  • Switch chip model 98DX3257
  • Dimensions 443 x 382 x 44 mm
  • RouterOS license 5
  • Operating System RouterOS v7 / SwitchOS
  • Size of RAM 128 MB
  • Storage size 32 MB
  • Storage type FLASH
  • Tested ambient temperature -20°C to 60°C
Powering
  • Number of AC inputs 1
  • AC input range 100-240
  • Number of PSU slots 1
  • Frequency (Hz) 50-60
  • Max power consumption 800 W
  • Max power consumption without attachments 85 W
  • Cooling type 4 fans
PoE-out
  • PoE-out ports Ether1-Ether48
  • PoE out 802.3af/at
  • Low voltage PoE-Out current limit 1000 mA
  • High voltage PoE-Out current limit 570 mA
  • Total output current 27A at 26V OR 13.2A at 53V
  • Total output power 700W
Ethernet
  • 10/100 Ethernet ports 1
  • 10/100/1000 Ethernet ports 48
Fiber
  • SFP+ ports 4
  • Number of 40G QSFP+ ports 2
Peripherals
  • Serial console port RJ45
Other
  • CPU temperature monitor Yes
  • Current Monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP20
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.20.5 download files for mipsbe devices.
Latest SwitchOS release v2.18 download files for css354 devices.
System Package
More
Netinstall:
More in download page
Related Products
