Skip to main content
CRS326-24S+2Q+RM
One of our faster switches for the most demanding setups.
Dual boot
40G
ROS v7
SFP/SFP+
CRS326-24S+2Q+RM
Product image
Product image
Product image thumbnail
If you are working with substantial amount of data – like providing Internet access or maintaining a huge data center – this is the perfect upgrade for your setup. CRS326-24S+2Q+RM is our first product with 40 Gbps QSFP+ ports for remarkably fast and stable fiber connection.
Overall it has two 40 Gbps QSFP+ ports and twenty four 10 Gbps SFP+ ports, which provides total nonblocking throughput of 320 Gbps and switching capacity of 640 Gbps with forwarding rate of 252 Mpps with most common packets.
CRS326-24S+2Q+RM is easy to manage – it has a full size USB port for configuration and dual power supply for redundancy – no unexpected downtime, your clients and colleagues will be thankful!
You can choose between our legendary feature-packed RouterOS for booting or a simpler, but still powerful SwOS. If you would like the ability to use routing and other Layer 3 features in your CRS, use RouterOS
Specification
Specifications
  • Product code CRS326-24S+2Q+RM
  • Suggested price $599.00
  • Architecture MIPSBE
  • CPU QCA9531
  • CPU core count 1
  • CPU nominal frequency 650 MHz
  • Switch chip model 98DX8332
  • Dimensions 443 x 200 x 44 mm
  • RouterOS license 5
  • Operating System RouterOS v7 / SwitchOS
  • Size of RAM 128 MB
  • Storage size 32 MB
  • Storage type FLASH
  • Tested ambient temperature -20°C to 60°C
Powering
  • Number of AC inputs 2
  • AC input range 100-240
  • Number of PSU slots 2
  • Frequency (Hz) 50-60
  • Max power consumption 69 W
  • Max power consumption without attachments 42 W
  • Cooling type 3 fans
Ethernet
  • 10/100 Ethernet ports 1
Fiber
  • SFP+ ports 24
  • Number of 40G QSFP+ ports 2
Peripherals
  • Serial console port RJ45
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP20
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.20.6 download files for mipsbe devices.
Latest SwitchOS release v2.18 download files for css326q devices.
More in download page
