CCR1009-8G-1S-PC
8x Gigabit Ethernet, 1xSFP cage,
9 cores x 1GHz CPU, 1GB RAM, passive cooling case, RouterOS L6
Discontinued
Our popular 9-core Cloud Core Router is now available in a new passive cooling enclosure.
This CCR1009 unit is equipped with two heat-pipes and a specially designed heat-sink, so its completely silent.
The unit is powered by an external 24v 2.5A AC/DC adapter and supports power redundancy if you also power it from the PoE input port.
Send purchase questions
Specifications
Details |
Product code |
CCR1009-8G-1S-PC |
Architecture |
TILE |
CPU |
TLR4-00980 |
CPU core count |
9 |
CPU nominal frequency |
1 GHz |
Switch chip model |
AR8327 |
Dimensions |
272x190x47mm |
RouterOS license |
6 |
Operating System |
RouterOS |
Size of RAM |
1 GB |
Storage size |
128 MB |
Storage type |
NAND |
MTBF |
Approximately 200'000 hours at 25C |
Tested ambient temperature |
-20°C to 60°C |
Suggested price |
$425.00 |
Powering
Details |
Number of DC inputs |
2 (DC jack, PoE-IN) |
DC jack input Voltage |
14-57 V |
Max power consumption |
34 W |
Cooling type |
Passive |
PoE in |
Passive PoE |
PoE in input Voltage |
14-57 V |
Ethernet
Details |
10/100/1000 Ethernet ports |
8 |
Fiber
Peripherals
Details |
Serial console port |
RS232 + Header |
Number of USB ports |
1 |
USB Power Reset |
Yes |
USB slot type |
microUSB type AB |
Max USB current (A) |
1 |
Other
Details |
CPU temperature monitor |
Yes |
Current Monitor |
Yes |
PCB temperature monitor |
Yes |
Voltage Monitor |
Yes |
Beeper |
Yes |
Certification & Approvals
Details |
Certification |
CE, EAC, ROHS |
Included parts
SFP compatibility listOpen
RouterOS software manualOpen
High resolution images
Ethernet test results
- All tests are done with Xena Networks specialized test equipment (XenaBay),and done according to RFC2544 (Xena2544)
- Max throughput is determined with 30+ second attempts with 0,1% packet loss tolerance in 64, 512, 1518 byte packet sizes
- Test results show device maximum performance, and are reached using mentioned hardware and software configuration, different configurations most likely will result in lower results
The device has an operating system preinstalled and licensed. No separate purchase is necessary and the product is ready to use. The device includes free software updates for the life of the product or a minimum of 5 years starting from date of purchase..
Related products
