Skip to main content
CRS328-24P-4S+RM
24 port Gigabit Ethernet router/switch with four 10Gbps SFP+ ports in 1U rackmount case, Dual Boot and PoE output, 500W
ARM
Dual boot
PoE
SFP/SFP+
CRS328-24P-4S+RM
Product image
Product image
Product image thumbnail
CRS328-24P-4S+RM is a 28 independent port switch, it has 24 Gigabit Ethernet ports, which offer different power output options: Passive PoE, low voltage PoE, 802.3af/at (Type 1 “PoE” / Type 2 “PoE+”) with auto-sensing. PoE-Out is passed over mode B pins (4,5+)(7,8-). The four SFP+ ports provide up to 10 Gbps connectivity options via either optical fiber or Ethernet modules (not included).
CRS328-24P-4S+RM comes in a 1U rackmount case with 100-240 V AC 500 W power supply built-in. The device consumes up to 44 W leaving guaranteed 450 W (3x150 W per every 8 Ethernet ports) to power your PoE devices. Each port can provide up to 30 W of power with any power output option you choose.
The device has a “Dual boot” feature that allows you to choose between two operating systems - RouterOS or SwOS. If you prefer to have a simplified operating system with only switch specific features, use SwOS. If you would like the ability to use routing and other Layer 3 features in your CRS, use RouterOS. You can select the desired operating system from RouterOS, from SwOS or from the RouterBOOT loader settings. All the feature set comes with disruptive price, providing best price/performance on the market.
Specification
Specifications
  • Product code CRS328-24P-4S+RM
  • Suggested price $489.00
  • Architecture ARM 32bit
  • CPU 98DX3236
  • CPU core count 1
  • CPU nominal frequency 800 MHz
  • Switch chip model 98DX3236
  • Dimensions 443 x 300 x 44 mm
  • RouterOS license 5
  • Operating System RouterOS / SwitchOS
  • Size of RAM 512 MB
  • Storage size 16 MB
  • Storage type FLASH
  • Tested ambient temperature -20°C to 60°C
Powering
  • Number of AC inputs 1
  • AC input range 100-240
  • Number of PSU slots 2
  • Max power consumption 494 W
  • Max power consumption without attachments 44 W
  • Cooling type 2 fans
PoE-out
  • PoE-out ports Ether1-Ether24
  • PoE out 802.3af/at
  • Low voltage PoE-Out current limit 1000 mA
  • High voltage PoE-Out current limit 450 mA
  • Max total out (A) 20 A
Ethernet
  • 10/100/1000 Ethernet ports 24
Fiber
  • SFP+ ports 4
Peripherals
  • Serial console port RJ45
Other
  • CPU temperature monitor Yes
  • Current Monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Mode button Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP00
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.20.6 download files for arm devices.
Latest SwitchOS release v2.18 download files for css328p devices.
More in download page
