Skip to main content
CRS326-24G-2S+IN
24 Gigabit ports, 2 SFP+ cages and a desktop case – server room power for your home!
ARM
Dual boot
PoE
SFP/SFP+
CRS326-24G-2S+IN
Product image
Product image
Product image
Product image thumbnail
A home network setup doesn’t have to be a compromise. This compact and quiet switch is packing some serious server room grade features: a pair of 10G SFP+ cages, 512 MB of RAM, 24 Gigabit Ethernet ports and a sufficient built-in CPU that can handle basic home user needs such as firewall, NAT and even some VPN. And it is extremely affordable – we are keeping the price on par with the previous generation desktop switches!
Like many other MikroTik switches, CRS326-24G-2S+IN offers the dual boot option that allows you to use either the lightweight SwOS or the advanced RouterOS. The compact and quiet fanless desktop case makes this switch the perfect addition to the best home setups. And it is very easy to transport! But make no mistake – this small switch has all the power and features of its bigger rackmount analogue – the CRS326-24G-2S+RM, nothing has been removed!
CRS326-24G-2S+IN provides all the basic functionality for a managed switch, and even more: port-to- port forwarding, MAC filtering, VLAN configuration, traffic mirroring, bandwidth limitation and even adjust some MAC and IP header fields. SFP+ cage supports both 1.25G SFP and 10G SFP+ modules.
Specification
Specifications
  • Product code CRS326-24G-2S+IN
  • Suggested price $199.00
  • Architecture ARM 32bit
  • CPU 98DX3236
  • CPU core count 2
  • CPU nominal frequency 800 MHz
  • Switch chip model 98DX3236
  • Dimensions 285 x 144 x 44 mm
  • RouterOS license 5
  • Operating System RouterOS / SwitchOS
  • Size of RAM 512 MB
  • Storage size 16 MB
  • Storage type FLASH
  • Tested ambient temperature -40°C to 60°C
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 10-30 V
  • Max power consumption 21 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 10-30 V
Ethernet
  • 10/100/1000 Ethernet ports 24
Fiber
  • SFP+ ports 2
Peripherals
  • Serial console port RJ45
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP20
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.20.6 download files for arm devices.
Latest SwitchOS release v2.18 download files for css326 devices.
More in download page
