Skip to main content
CRS317-1G-16S+RM
Smart Switch, 1 x Gigabit LAN, 16 x SFP+ cages, Dual Core 800MHz CPU, 1GB RAM, 1U rackmount passive cooling case, Dual Power Supplies
ARM
Dual boot
SFP/SFP+
CRS317-1G-16S+RM
Product image
Product image
Product image thumbnail
The new Cloud Router Switch 317-1G-16S+RM is a rack-mountable manageable switch with Layer3 features, it has 16 SFP+ ports for high performance 10GbE connectivity and a 1GbE copper port for management.
CRS317-1G-16S+RM is powered by a next generation switching chip, giving you wire speed performance for all sixteen 10GbE ports with any Ethernet frame size. New features such as hardware-based Spanning Tree Protocol and Link Aggregation (LACP) provide enhanced protection and true professional performance for your demanding network.
The unit has dual redundant power supplies and passive cooling case - for hot environments two redundant fans will automatically keep the system cool if needed.
Specification
Specifications
  • Product code CRS317-1G-16S+RM
  • Suggested price $499.00
  • Architecture ARM 32bit
  • CPU 98DX8216
  • CPU core count 2
  • CPU nominal frequency 800 MHz
  • CPU Threads count 2
  • Switch chip model 98DX8216
  • Dimensions 443 x 224 x 44 mm
  • RouterOS license 6
  • Operating System RouterOS / SwitchOS
  • Size of RAM 1 GB
  • Storage size 16 MB
  • Storage type FLASH
  • Tested ambient temperature -20°C to 60°C
Powering
  • Number of AC inputs 2
  • AC input range 100-240
  • Number of PSU slots 2
  • Frequency (Hz) 50-60
  • Max power consumption 44 W
  • Cooling type 2 fans
Ethernet
  • 10/100/1000 Ethernet ports 1
Fiber
  • SFP+ ports 16
Peripherals
  • Serial console port RJ45
Other
  • CPU temperature monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.20.6 download files for arm devices.
Latest SwitchOS release v2.18 download files for css317 devices.
More in download page
