Skip to main content
PowerBox Pro
Five Gigabit Ethernet Router with 4xPoE-out ports, SFP cage and outdoor enclosure
Outdoors
PoE
SFP/SFP+
PowerBox Pro
Product image
Product image
Product image
Product image
Product image thumbnail
The PowerBox Pro is an outdoor five gigabit ethernet port router with PoE output on four ports. Since the device has a weatherproof outdoor case, you can mount it on a tower, or in other outdoor locations.
It also supports passive PoE input and passive or 802.3af/at PoE output. Ethernet ports 2-5 can power other PoE capable devices with the same voltage as applied to the unit. Less power adapters and cables to worry about! It can power 802.3at and af mode B compatible devices, if 48-57 input voltage is used.
The device has a SFP port for adding optical fiber connectivity. It is affordable, small and easy to use, but at the same time comes with a very powerful 800MHz CPU, capable of all the advanced configurations that RouterOS supports.
Specification
Specifications
  • Product code RB960PGS-PB
  • Suggested price $109.00
  • Architecture MIPSBE
  • CPU QCA9557
  • CPU core count 1
  • CPU nominal frequency 800 MHz
  • Switch chip model QCA8337
  • Dimensions 125 x 52 x 225 mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 128 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 12-57 V
  • Max power consumption 54 W
  • Max power consumption without attachments 6 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 12-57 V
PoE-out
  • PoE-out ports Ether2-Ether5
  • PoE out 802.3af/at
  • Low voltage PoE-Out current limit 1 A
  • High voltage PoE-Out current limit 450 mA
  • Max total out (A) 2 A
Ethernet
  • 10/100/1000 Ethernet ports 5
Fiber
  • SFP ports 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
Included parts
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.20.6 download files for mipsbe devices.
System Package
More in download page
