Skip to main content
Discontinued
NetMetal 5SHP triple
Triple chain 5GHz integrated 802.11ac AP/Backbone/CPE, 3xRPSMA connectors, high power, Gigabit Ethernet, waterproof metal enclosure
IP 54
Outdoors
PoE
SFP/SFP+
Product image
Product image
Product image
Product image
Product image thumbnail
The NetMetal is a 802.11a/n/ac wireless device in a waterproof metal enclosure. Its rugged design is made to withstand the toughest conditions, but at the same time is easy to use and can be opened and closed with one hand. The solid aluminum enclosure also works as a reliable heat-sink for it’s high output power radio. It is sealed to conform with the IP54 standard.
The NetMetal is equipped with powerful 720Mhz CPU, 128MB RAM, one Gigabit Ethernet port, 802.11ac wireless, one SFP cage, USB, RP-SMA connectors for external antennas and RouterOS L4 license.
RB921UAGS-5SHPacT-NM version is equipped with Super High power 3x3 Tripple Chain 802.11ac wireless and three RP-SMA connectors for external antennas
- RB921UAGS-5SHPacT-NM-US (USA) is factory locked for 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
- RB921UAGS-5SHPacT-NM (International) supports 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
Specification
Specifications
  • Product code RB921UAGS-5SHPacT-NM
  • Suggested price $169.00
  • Architecture MIPSBE
  • CPU QCA9557
  • CPU core count 1
  • CPU nominal frequency 720 MHz
  • Dimensions 143x247x48mm (PCB)
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 128 MB
  • Storage size 128 MB
  • Storage type NAND
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 25 W
  • Max power consumption without attachments 21W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 8-30 V
Wireless specifications
  • Wireless 5 GHz Max data rate 1300 Mbit/s
  • Wireless 5 GHz Number of chains 3
  • Wireless 5 GHz standards 802.11a/n/ac
  • Wireless 5 GHz chip model QCA9880
  • Wireless 5 GHz generation Wi-Fi 5
Ethernet
  • 10/100/1000 Ethernet ports 1
Fiber
  • SFP DDMI yes
  • SFP ports 1
Peripherals
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP IP54
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.20.6 download files for mipsbe devices.
System Package
More in download page
