Skip to main content
CRS326-24G-2S+RM
24 Gigabit port switch with 2 x SFP+ cages in 1U rackmount case, Dual boot (RouterOS or SwitchOS)
ARM
Dual boot
PoE
SFP/SFP+
CRS326-24G-2S+RM
Product image
Product image
Product image
Product image thumbnail
SwOS/RouterOS powered 24 port Gigabit Ethernet switch with two SFP+ ports, wire speed connectivity with several new switching features!
It has “Dual boot” feature that allows you to choose which operating system you prefer to use, RouterOS or SwOS. If you prefer to have a simplified switch only OS with more switch specific features, use SwOS. If you are used to Winbox and would like the ability to use routing and other Layer 3 features on some ports in your CRS, boot and use RouterOS. You can select the desired operating system from RouterOS, from SwOS or from the RouterBOOT loader settings.
It gives you all the basic functionality for a managed switch, plus more: allows to manage port-to-port forwarding, apply MAC filter, configure VLANs, mirror traffic, apply bandwidth limitation and even adjust some MAC and IP header fields. SFP cage supports both 1.25 Gb SFP and 10 Gb SFP+ modules.
Specification
Specifications
  • Product code CRS326-24G-2S+RM
  • Suggested price $209.00
  • Architecture ARM 32bit
  • CPU 98DX3236
  • CPU core count 2
  • CPU nominal frequency 800 MHz
  • Switch chip model 98DX3236
  • Dimensions 443 x 144 x 44 mm
  • RouterOS license 5
  • Operating System RouterOS / SwitchOS
  • Size of RAM 512 MB
  • Storage size 16 MB
  • Storage type FLASH
  • Tested ambient temperature -40°C to 60°C
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 10-30 V
  • Max power consumption 24 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 10-30 V
Ethernet
  • 10/100/1000 Ethernet ports 24
Fiber
  • SFP+ ports 2
Peripherals
  • Serial console port RJ45
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP20
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.20.6 download files for arm devices.
Latest SwitchOS release v2.18 download files for css326 devices.
More in download page
