Products
Products
    XQ+DA0001 A 40/100 Gbps QSFP28 direct attach cable, 1m long. Enables easy direct connectivity between two 100 Gigabit devices. Fairly flexible.
    Connect any two MikroTik 100 Gigabit heroes (CCR2216 & CRS504) without a hassle - this cable has integrated QSFP28 modules. Just plug it in and enjoy the speed! The cable is one meter long, which should be enough for most setups, but there is also a 3-meter version available. It is fairly flexible – you can keep your devices apart or on top of each other.
     Send purchase questions
    Product specifications
    Details
    Product code XQ+DA0001
    Cable length 1m
    Connector QSFP+ to QSFP+ / QSFP28 to QSFP28
    Data Rate 40G / 100G
    Suggested price $39
    BrochureOpen
    High resolution images
    Related products
