Skip to main content
Discontinued
CCR1036-12G-4S
1U rackmount, 12x Gigabit Ethernet, 4xSFP cages, LCD, 36 cores x 1.2GHz CPU, 4GB RAM, 24 mpps fastpath, Up to 16Gbit/s throughput, RouterOS L6, Dual PSU
M.2
SFP/SFP+
CCR1036-12G-4S
Product image
Product image
Product image thumbnail
CCR1036-12G-4S is an industrial grade router with cutting edge 36 core CPU. If you need many millions of packets per second - Cloud Core Router with 36 cores is your best choice.
The device comes in a 1U rackmount case, has four SFP ports, twelve Gigabit ethernet ports, a serial console cable and a USB port.
The new r2 version has onboard 4GB of RAM, onboard M.2 slot, full size USB slot and dual PSU for redundancy!
Specification
Specifications
  • Product code CCR1036-12G-4S
  • Suggested price $1,095.00
  • Architecture TILE
  • CPU TLR4-03680
  • CPU core count 36
  • CPU nominal frequency 1.2 GHz
  • CPU Threads count 36
  • Dimensions 443 x 193 x 44 mm
  • RouterOS license 6
  • Operating System RouterOS
  • Size of RAM 4 GB
  • Storage size 1 GB
  • Storage type NAND
  • Tested ambient temperature -20°C to 60°C
Powering
  • Number of AC inputs 2
  • AC input range 100-240
  • Number of PSU slots 2
  • Frequency (Hz) 50-60
  • Max power consumption 60 W
  • Cooling type 2 fans
Ethernet
  • 10/100/1000 Ethernet ports 12
Fiber
  • SFP DDMI Yes
  • SFP ports 4
Peripherals
  • Serial console port RJ45
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
  • Number of M.2 slots 1
Other
  • CPU temperature monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Mode button Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP20
Included parts
Note
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.20.6 download files for tile devices.
More in download page
