Products
Products
    TOF-2400-8V-4 Omni antenna A 2.4 GHz 8 dBi Omni Antenna for the wAP LR2 kit. If necessary, this antenna can be used for any 2.4 GHz device.
    Working with the wAP LR2 kit or similar setups? For extra network coverage (up to 3-4km in the line of sight), we suggest adding an external 8 dBi Omni antenna - the TOF-2400-8V-4.If necessary, this antenna can be used for any 2.4 GHz device. Not only it works with the 2.4 GHz LoRa® connectivity, it also supports the regular 2.4 GHz WLAN. It comes with a 1m long SMA cable and a mechanical holder for quick and easy mast attachment – when you need that extra network coverage. Compact size and increased durability without sacrificing the power – this antenna will get the job done.
     Send purchase questions
    Product specifications
    Details
    Product code TOF-2400-8V-4
    Suggested price $49
    BrochureOpen
    Mounting instructionOpen
    High resolution images
    Related products
