Skip to main content
Discontinued
wAP 60G
60 GHz CPE with Phase array 60° beamforming Integrated antenna, 716 Mhz CPU, 256 MB RAM, PSU and PoE, RouterOS L3
ARM
Quad-core CPU
IP 55
Outdoors
PoE
wAP 60G
Product image
Product image
Product image thumbnail
The wAP 60G is weatherproof integrated 60 GHz wireless unit, that can be used indoors or outdoors as Point-to-Point or CPE unit
The box includes a wall mounting kit, straps for pole mounting, power supply, PoE injector and also table stand for using the device indoors. Penetrates some windows depending on material.
wAP 60G connects to 60 GHz AP for distances of 200m+
Specification
Specifications
  • Product code RBwAPG-60ad
  • Suggested price $114.00
  • Architecture ARM 32bit
  • CPU IPQ-4019
  • CPU core count 4
  • CPU nominal frequency 448-896 (auto) MHz
  • CPU Threads count 4
  • Dimensions 185 x 85 x 30 mm
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 256 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 12-57 V
  • Max power consumption 5 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 12-57 V
Ethernet
  • 10/100/1000 Ethernet ports 1
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP 55
Included parts
Note
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.23.2 download files for arm devices.
System Package
More in download page
