Discontinued
SXT 6 is our first product for licensed 5.9-6.4GHz frequency. Equipped with RouterOS Level 4 license and 28 degree Dual Chain 16dBi antenna, unit can be used as Base Station or CPE, as well as two of them can be used to create Point-to-Point link.
IMPORTANT! Product is available for 5.9-6.4GHz license holders only, you would need to show your license to Distributor to be able to place your order.
This product is not suitable for unlicensed ISM bands. Device use is subject to country regulations. Availability might be limited depending on distributor stock and country regulations.
Send purchase questions
Specifications
Details |
Product code |
RBSXTG-6HPnD |
Architecture |
MIPSBE |
CPU |
AR9344 |
CPU core count |
1 |
CPU nominal frequency |
600 MHz |
Dimensions |
140x140x56mm |
RouterOS license |
4 |
Operating System |
RouterOS |
Size of RAM |
64 MB |
Storage size |
16 MB |
Storage type |
FLASH |
MTBF |
Approximately 100'000 hours at 25C |
Tested ambient temperature |
-40°C to 70°C |
Suggested price |
$99.00 |
Powering
Details |
Number of DC inputs |
1 (PoE-IN) |
Max power consumption |
14 W |
Cooling type |
Passive |
PoE in |
Passive PoE |
PoE in input Voltage |
7-30 V |
Wireless specifications
Details |
Wireless 6 GHz Max data rate |
300 Mbit/s |
Wireless 6 GHz number of chains |
2 |
Wireless 6 GHz standards |
802.11a/n |
Antenna gain dBi for 6 GHz |
16 |
Wireless 6 GHz chip model |
AR9344 |
Wireless 6 GHz generation |
Wi-Fi 4 |
Ethernet
Details |
10/100/1000 Ethernet ports |
1 |
Peripherals
Details |
Number of USB ports |
1 |
USB Power Reset |
Yes |
USB slot type |
USB type A |
Max USB current (A) |
1 |
Other
Details |
PCB temperature monitor |
Yes |
Voltage Monitor |
Yes |
Beeper |
Yes |
Certification & Approvals
Details |
Certification |
EAC |
6 GHz | Transmit (dBm) | Receive Sensitivity |
6MBit/s | 30 | -93 |
54MBit/s | 27 | -80 |
MCS0 | 29 | -93 |
MCS7 | 24 | -76 |
Included parts
RouterOS software manualOpen
High resolution images
Ethernet test results
- All tests are done with Xena Networks specialized test equipment (XenaBay),and done according to RFC2544 (Xena2544)
- Max throughput is determined with 30+ second attempts with 0,1% packet loss tolerance in 64, 512, 1518 byte packet sizes
- Test results show device maximum performance, and are reached using mentioned hardware and software configuration, different configurations most likely will result in lower results
The device has an operating system preinstalled and licensed. No separate purchase is necessary and the product is ready to use. The device includes free software updates for the life of the product or a minimum of 5 years starting from date of purchase..
