Products
Products
    Q+BC0003-S+ 40 Gbps QSFP+ break-out cable to 4x10G SFP+
    Discontinued
    This cable will let you enjoy all the benefits of our new switch with the 40 Gbps ports without upgrading your whole network setup. You can connect the CRS326-24S+2Q+RM to 4 other 10G SFP+ devices in a breeze, since the QSFP+ and SFP+ modules are integrated. The cable is 3 meters long, which should be enough for most setups.
     Send purchase questions
    Product specifications
    Details
    Product code Q+BC0003-S+
    Cable length 3m
    Connector QSFP+ to SFP+
    Data Rate 40G
    Tested ambient temperature 0°C .. +70°C
    Suggested price $59
    BrochureOpen
    SFP compatibility listOpen
    High resolution images
    Related products
