Skip to main content
hEX S (2025)
A compact, affordable wired router featuring a 2.5G SFP port, 5x Gigabit Ethernet, PoE out, USB, and a fast dual-core CPU – ideal for homes, offices, or underfunded labs that need reliable performance.
2.5G SFP uplink
5 x 1G ethernet (bonding support)
PoE Input & PoE Output
USB 3 port for storage & file sharing
Dual-Core ARM CPU + 512 MB RAM
Flexible powering (12–57 V)
RouterOS v7
Wall-mountable design
Need a wired router that won’t slow you down or drain your budget? The new hEX S is a compact, truly budget-friendly device that does a little bit of everything — and does it fast. Whether you’re building a smart home, running a local lab, or just want a clean, powerful wired setup, this is your new Ethernet essential.
With 5× Gigabit Ethernet ports (including PoE Input on port #1 and PoE Output on port #5), plus a 2.5 Gigabit SFP cage, this compact router can adapt to many roles. And unlike most ISP boxes, you can assign any port as WAN, LAN, or bridge — full flexibility right out of the box. That’s just the beginning. RouterOS v7 gives you advanced routing, VLANs, bonding, traffic shaping, and more — so you can build the wired network you’ve always wanted.
Background image
Background image
Max Your Internet Plan
Got a 2 Gbps fiber plan? Use the 2.5G SFP port to deliver that speed to your power-hungry devices — from self-hosted movie servers to media workstations or security camera NVRs. Perfect for homes, small offices, and media studios.
Background image
Local Speed for Creators
Connect your PC over 2.5G, then bond two 1G ports to your NAS. Enjoy ultra-fast file transfers, smooth backups, and zero bottlenecks — ideal for creators, editors, and researchers who work with large files.
hEX S — higher speed and better connectivity on a smaller budget.
Because every network deserves an upgrade.
hEX S (2025)
Product image
Product image
Product image thumbnail
Specification
Specifications
  • Product code E60iUGS
  • Suggested price $69.00
  • Architecture ARM 32bit
  • CPU EN7562CT
  • CPU core count 2
  • CPU nominal frequency 950 MHz
  • CPU Threads count 2
  • Switch chip model EN7523
  • RouterOS license 4
  • Operating System RouterOS v7
  • Size of RAM 512 MB
  • Storage size 128 MB
  • Storage type NAND
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 12-57 V
  • Max power consumption 23 W
  • Max power consumption without attachments 5 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 18-57 V
PoE-out
  • PoE-out ports Ether5
  • PoE out Passive PoE up to 57V
  • Low voltage PoE-Out current limit 0.5 A
  • High voltage PoE-Out current limit 0.5 A
Ethernet
  • 10/100/1000 Ethernet ports 5
  • Number of 1G Ethernet ports with PoE-out 1
Fiber
  • SFP ports 1 (2.5G supported)
Peripherals
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB 3.0 type A
  • Max USB current (A) 1
Other
  • CPU temperature monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Mode button Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP 20
Included parts
Note
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.1 download files for arm devices.
System Package
More in download page
